Question Painting Cast Iron 911 Cylinders
Can anyone recommend a paint for the cast iron cylinders on my 2.4?
I am aware that too much or the wrong kind of paint can interfere with heat transfer. Rust doesn't transfer heat very effectively either.
Anyone try any of the PJ1 motorcycle engine case & barrel paints?
Thanks,
Bill
Triplesn8s
'72 911T Coupe - Resto Proceeding at a Snails Pace
‘80 TR8 Convert - SOLD
'78 TR8 Coupe - Autocross Project
'06 Ducati 1000SS/DS - ‘11 H-D XR1200x
Old 11-19-2004, 01:14 PM
high heat black wrinkle finish. black dissipates heat too. heat them in the oven after painting to get the best wrinkle.
206 637 4071
Old 11-19-2004, 01:47 PM
Wo ist die Rennstrecke?
DonE's Avatar
You might want to consider a high heat dispersant powder coating. There is real data out there that proves the coatings work in disapating heat and evening out any hot spots.
Old 11-19-2004, 03:22 PM
Until there is data that shows how much an improvement in using a "heat dispersant" paint, I'd go with a light spray coat of flat black on top of clean base metal.
Sherwood
Old 11-19-2004, 04:07 PM
Navin Johnson
TimT's Avatar
I just had the oppurtunity to take apart a 2003 996 GT3 RS engine...The last people that turned a wrench on this engine was Porsche motorsports(or peter Dawe)..
the piston skirts seem to have been coated with "something"
the piston tops seem to have been coated with "something"
Thermal dispersants/barriers apparently do work.
I dont see any reason why coating the cylinders with thermal dispersant would hurt
'69 911 GT-5
'75 914 GT-3
and others
Old 11-19-2004, 04:25 PM
DonE's Avatar
The data shows that the coating disapates heat 2x faster than bare aluminum - pretty impressive knowing aluminum's properties. On the other hand, if you think this is "snake oil", don't do it...
If you are interested, use Google and do a search on Thermal Dispersants. Or try this:
http://www.techlinecoatings.com/introduction.html
They supply most of the automotive coating people.
Old 11-19-2004, 08:56 PM
I would rather be driving
jpnovak's Avatar
Thanks for the link. I know I will be shopping there. Dry film coatings on the piston skirts and ceramic coatings on pistions, valves and posstibly more. Oh and I can't forget the jet-hot like exhaust coatings.
Old 11-20-2004, 06:06 AM
Other than Techline's claims or other companies that use Techline's product, I didn't see the data you were referring to on their website. In addition, I couldn't find any thermal dispersant studies during a Google search. Do you have any data you can share?
Thanks,
Sherwood
Old 11-20-2004, 03:56 PM
Navin Johnson
TimT's Avatar
Just this afternoon, I held a 2003 996 GT3RS piston.. and compared it to an earlier cupcar piston.
The -03 GT3RS piston has some sort of coating on it!
This engine was from a car that ran the 24 hours of Lemans last year..
thermal barriers look evident, anti friction coatings are evident..
Someone someplace is applying these coatings..
I love to open up an engine, where the last people that touched it works in Weisach
'69 911 GT-5
'75 914 GT-3
and others
Old 11-20-2004, 04:47 PM
I have used the Techline Coatings thermal dispersant coating on every cast iron cylinder that I have had nikasil plated and have had great success with it. My only complaint with it, and other commercially/professionally applied coatings are that they are susceptible to flaking and chipping.
Charles Navarro
LN Engineering
http://www.LNengineering.com
Aircooled Precision Performance
Old 11-21-2004, 05:36 AM
