911 2.4 Piston Rings - If not Deves, Who?
Techies,
I am re-ringing 2.4T (cast iron cylinders) and would appreciate some recommendations on piston rings. I have seen some negative comments on Deves.
My existing rings are not resusable, this motor i presume had been re-ringed one before and not honed so the rings have a burr on the top edge. Otherwise bores are nice & round & should hone out at the max listed clearance.
My other concern is that the rings I would buy would be too closely matched to a smaller bore/clearance not giving me enough "end" to set end gaps properly.
I am considering going "gapless" with Total Seal or someone similar. Since I don't need to worry about Nickies/Alusil I should have some flexibility.
Knowledgable feedback is gratefully appreciated.
Bill
Triplesn8s
'72 911T Coupe - Resto Proceeding at a Snails Pace
‘80 TR8 Convert - SOLD
'78 TR8 Coupe - Autocross Project
'06 Ducati 1000SS/DS - ‘11 H-D XR1200x
Old 11-19-2004, 07:11 AM
Goetze.
206 637 4071
Old 11-19-2004, 08:28 AM
fancytown
I wouldn't sweat this one too much. You have a 2.4 T motor (like myself), and aren't going to be pushing any serious power. I went with Deves because it was the easiest for me to find. Then again, I used 2.2T Kolbenschmidt pistons/cylinders (different ring height than Mahle). The price was right on the P/C's, and I get a compression bump. My cylinders were used, and re-honed also. So far, with 800 miles on the rebuild, it's looking A-OK.
all cars sold.
Old 11-19-2004, 03:55 PM
Navin Johnson
TimT's Avatar
Goetze or Total Seal.
'69 911 GT-5
'75 914 GT-3
and others
Old 11-19-2004, 04:08 PM
IMO, Total Seal are more gimmick than anything, and definitely not worth the extra price for an application like this.
Matt B
'73 911E
Old 11-21-2004, 02:33 AM
Goetze is my vote, if available. Another option most people don't consider is just calling up JE. I prefer using their XC ring set (available in most every combination) or secondly their JG.
Charles Navarro
LN Engineering
http://www.LNengineering.com
Aircooled Precision Performance
Old 11-21-2004, 05:34 AM
Nitrometano's Avatar
I have used Total Seal once. Good results.
1972 911T
1991 Mazda RX-7 Turbo II
Are you car loosing power? When was last time you service your fuel injectors? Dirty fuel injectors? Why no try a complete fuel injector cleaning service and return the dignity to you car. Visit www.rennsportfuel.com and we will return your injectors back to life!
Old 11-21-2004, 07:29 PM
Thanks for all the input guys. A plethora of good advice.
I am going to give Total Seal a try. Primarily because blowby in a 911 motor is soooo messy.
Bill
Triplesn8s
Old 11-22-2004, 12:04 PM
