bown 930 3.5 twin plug engine !! help
i am in trouble...overrevved my 930 turbo cab 1988'...it has twin plug heads,3.5 liter mahle pistons and cylinders.... i have 2 pistons and 2 sleeves that need replacing. i am not able to find just 2 pistons/cylindrrs,everyone wants to sell me a kit of 6... too expensive,. anyone has used parts or know of anyone with used parts or partially used kit...or simply leftovers ??
they are 100 mm pistons... |
try engine builder's supply.
they carry misc parts new or used for 911 turbo?
3.5 pistons
I just bought a couple new 100mm 3.5 turbo p&c's from Andial to replace 2 damaged ones on my engine. Give them a call they should have what you need on the self.
Re: 3.5 pistons
did they sell you 2 units or did you have to buy 6 units?? if you have leftovers from your old set,i would buy 2 from you now...
Sounds like he "just bought a couple" (not 6).
-Chris |
Check with all your regional porsche shops, they may have a nice used set you can pick from.
Since one of my cylinders was scratched but everything else in spec I picked up a decent 930 jug at a nearby shop for a reasonable price. With 100 mm cylinders that may not be as easy for you though. |
JE can probably make you a set of replacement pistons...
-Wayne |
what did engine builders supply say?
Millenium Technologies, or US Chrome should be able to refinish them to original specs,cheers,Antonio.
| All times are GMT -8. The time now is 11:51 PM. |
