dweymer's Avatar
Aluminum Case?
I wanted to verify that my case is the aluminium one before I plan the rebuild:
Type: 901/05
SN: 909549
I believe this is alu case used in the 911E, am I right?
Donnie
Currently Porsche-less.....
Old 11-24-2004, 06:44 PM
up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
Isnt that 67? Whatever, 66/67, same deal, it's an aluminum case.
Old 11-25-2004, 12:41 AM
Warren Hall Student
Bobboloo's Avatar
For what it's worth E motors didn't come along until 1969 when Porsche was using magnesium so technically speaking Porsche never made an aluminum cased E motor.
The interesting thing about you case is that the serial no. is from a 67' 911 because 67' coupe motors started at 909001 and go up but the Red Book shows that 67' coupes (excluding the S) came with motor type 901/06 which was the same motor basically as the 66' 901/05 motor except that the cams had decreased overlap for the valves. So my guess is that the early 67' coupes came with motor type 901/05 like yours before being changed during the production run.
Well I guess we may have found a new data point for the Red Book.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 11-25-2004, 02:22 AM
dweymer's Avatar
Thanks for the info, the serial number seemed strange to me too.
Donnie
Old 11-25-2004, 10:27 AM
