up-fixing der car(ma)
YTNUKLR's Avatar
Send a message via AIM to YTNUKLR
Stock Spigot diameter?
Just wondering what the actual spigot diameter was for 2.0, 2.2 and 2.7 engines...Thanks, Scott
Old 12-06-2004, 06:33 PM
Doesn't want/need a 3.6L
Carrera3.5L's Avatar
Hi Scott,
Case bore is 97mm for the 2.4/2.7 cases. 3.0/3.2/3.3 cases are all 103mm stock.
Ralph
1988 Carrera w/ 3.5L Twin-Plug
2008 Cayman S (coming soon)
Old 12-06-2004, 06:54 PM
97 can't be right for 2.0 to 2.4 if it's right for 2.7. A 2.4 case has to be bored for the 2.7 cylinders.
-Andy
Old 12-06-2004, 07:13 PM
-Andy
Andy,
I believe you're probably right with the 2.0/2.4 cases but the 2.7 case bore should be 97mm.
Ralph
Old 12-06-2004, 08:08 PM
YTNUKLR's Avatar
Thanks so much!
Old 12-07-2004, 05:59 AM
