2.7 Main Bearings
Does anyone know where I could find a set of 2nd over (.5mm over) main bearings for a 2.7. I have a case that has been fitted with case savers, shuffle pins and a carrera oil pump but unfortunately it was already align-bored .5mm. The crankshaft is standard so I need (STD I.D. / .5mm O.D.) on the main bearings. Any help is appreciated.
the dealer sells 1st over sets for a reasonable amount. don't know about 2nd over. they don't come as a set, you have to order each bearing.
To my knowledge there are no .5mm align bore bearings. It sounds like you will need to resize the case. ( pull all the case studs and surface the case halves enough to allow for align bore to standard or most likely 1st oversize.
Good luck |
2.7 cases are very common - I would find a used one and go from there...
-Wayne |
You can now only buy these as pairs of shells not as an entire set. I got mine after a LOT of searching because the part numbers have changed. I ended up paying a little over $400. Wayne's right, look for another case. T |
| All times are GMT -8. The time now is 08:08 PM. |
