Rebuild all in one gasket kits questions.......
1. Do they have rocker shaft seals?
2. Can one request custom seals such as silicone valve cover gaskets instead? 3. Do they have the green (vs. red) rings? 4. Do they have the Vitron (spelling?) seals for the case throughs? 5. Is it better to order these gaskets seperately instead? Thank you. |
Keep in mind my rebuild was last winter, but as I recall there were no rocker shaft seals, the valve cover gaskets were the graphite ones (that are still sitting in my garage as I went with silicon), the case and oil cooler rings are a mix of red and green and the case bolt seals are the blue ones, not the green vitron.
Kurt's got it. The rocker shaft seals are special order as they are not "standard".
Thanks!
| All times are GMT -8. The time now is 06:59 AM. |
