MFI Correlation Jets
Is there a supplier for the six MFI air correlation screws/jets ?
Mine have grooves on them - like they've been turned in too far - and some bent tips. I have tried to restore them as best I can - but would rather just replace them. Couldn't find them on Pelican search - any suggestions? |
I'd call call Matt Blast at Eurometrix and ask him.
Matt is a great MFI resource.
Scott, if nothing else works out for you, I'd recommend watching for T stacks on ebay or here. They pop up from time to time and they're not too expensive. |
Thanks, guys. I've been nosing around ebay but most of the stuff I've seen looks like the stuff at a swap meet - it already has the same wear. Just wanted to tune up the car a little while saving for an RS upgrade.
Scott
I'm sure a toolmaker/engineer could reface them, Try contacting the local model engineering society, they might be able to direct you to someone HTH Neven |
| All times are GMT -8. The time now is 12:17 PM. |
