which flywheel seal???
I'm confused... my flywheel seal seems to be leaking - this is the one you can see after removing the flywheel looking at the outside of the engine.
Checking with the parts catalog, I discovered two part # per Perlican parts site: 99911342640 Crankshaft to Flywheel Seal 99911326440 Flywheel Seal The parts catalog I have (Parts & Technical Reference Catalog by Porshce) and all the diagrams I have seen does not seem to show the Flywheel seal. So, which one do I need? Why one has the correct part #? |
bump.... anyone?
If I look at our host's catalog:
The 99911342640 is for the 78-89 Crank and the 99911326440 is for the 90-98 964/993 crank. I would think that for your 87 930 you would need the 99911342640 which is listed as K-113-426-40 by our host. |
Thank you John... I must have been blind :(
No problem, hope it fixes the leak.
Yes, that is correct. Here is a link:
http://www.pelicanparts.com/catalog/shopcart/911M/POR_911M_enginA_pg8.htm#item24 -Wayne |
| All times are GMT -8. The time now is 01:26 PM. |
