911 distributor flyweight springs
First time user looking for some good advice and answers,,,,
I am replacing a Marrelli distributor with a Bosch (to be able to replace the points with an Ignitor). The engine is a 71, 2.2 with Zenith carbs.
I have disassembled the Bosch distributor (pt # 0 231 159 008) and believe I have a very good unit except for the flyweight springs.
Does anyone have any idea as to where I might purchase new springs? Also, the spring post is adjustable by means of a slotted opening for the attachment screws. If I were to just center the slot, would that be an acceptable "rig" for the advance?
Thank you for your help and suggestions!
Len
Old 08-10-2004, 06:28 PM
http://centuryspring.com/
Literally millions of springs. That's the rub - finding the appropriate springs for the retrofit. You could let their tech people analyze what you have, then come up with some alternate springs.
Sherwood
Old 08-10-2004, 08:04 PM
I had a hard time finding Bosch springs for my dist. I ended up getting Chevy V8 springs from a local speed shop. Summit racing sells them also.
Dean
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 08-11-2004, 06:00 PM
