-   -   P222 and P221 Chain and rod support tools make my own? Any one have a close-up pic? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/196732-p222-p221-chain-rod-support-tools-make-my-own-any-one-have-close-up-pic.html)
H.G.P. 12-13-2004 05:44 PM
I see in Wayne's book I can make my own. I can see them pictured in the book but not close-up , but I'd like a close up picture if any one has one or two.
Also where do the bottom of the support legs sit? Pictures?
Thanks!
Rot 911 12-13-2004 06:58 PM
I made mine out of cardboard and they worked just fine. I believe his book has the measurements of the tools. Once you make them it is fairly self explanatory of how they are used.
David 12-13-2004 07:48 PM
I used some thin gauge sheet metal (the thinner the better) and made them to the drawings in the book. I'd go take a picture but they look just like in the book.
H.G.P. 12-13-2004 08:43 PM
OK, but I see the picture in the book, but I can't tell for certain where the "tools" are, especially the one that's holding the chain.
David 12-13-2004 09:04 PM
Actually, I didn't use the one for the chain. I just let them hang loose and didn't have any problems.
H.G.P. 12-13-2004 09:20 PM
Does that mean holding the subject chain by hand until the halves are just about to mate?
Also on the adjacent page photo 3-19 the chain is also in the air but no support is shown????
David 12-13-2004 09:34 PM
I went out to the garage and checked my tools. I did infact make a chain holder. It has 15" legs with a 1/2" flat at the top. I put the feet on the sprocket to hold the chain up.
BK911 12-14-2004 06:05 AM
I use 12 gauge wire. You need about a foot. Strip the outer insulation and use the individual wires. Shape them into an inverted V, with the top bent to go through the top of the rod. The bottoms just go into the case next to the rods with friction holding them in place.
emcon5 12-14-2004 10:48 AM
The best solution I have seen for the rods is rubber bands.
http://forums.pelicanparts.com/uploa...1086619424.jpg
john walker's workshop 12-14-2004 11:58 AM
700+ posts and we still don't know your name or where you're from. time to add a signature and a location, please?
Rot 911 12-14-2004 01:13 PM
He has been asked to do this a number of times. For whatever reason, he appears to want to remain anonymous.
BK911 12-14-2004 01:23 PM
Nevermind...
H.G.P. 12-14-2004 05:35 PM
Yes, I did awhile back.
Kirk.
Wayne 962 12-15-2004 12:53 AM
Look very carefully, the green arrow is pointing to the support. I positioned that arrow so it's pointing *exactly* at the tool (under the chain, lifting it up in the air). See also 3-21 for more clarity.
-Wayne
Wayne 962 12-15-2004 12:54 AM
Re: P222 and P221 Chain and rod support tools make my own? Any one have a close-up pic?
Hmm, odd request. I can't get any closer than photo 3-17 on page 130. See the dimensions in that photo...
-Wayne
P.S. The factory now charges like $300 for these?!?
Wayne 962 12-15-2004 12:55 AM
Hmm, that's clever, but the whole point of these rod tools is to support the rods *before* you put the case half together...
-Wayne
H.G.P. 12-15-2004 09:32 PM
Re: Re: P222 and P221 Chain and rod support tools make my own? Any one have a close-up pic?
-Wayne
Odd? I've been over those photos. I cannot see for instance where exactly the "bottom" ("legs") of the chain holder is suppose to rest. It's inside the chain correct?, but where do the "legs" rest?
And the "legs" for the rods, do I assume they just sit in the case?
Rdkc01 08-02-2023 09:02 AM
Here is an excellent video of the use of the P221 from KURT DONOHOE
https://www.youtube.com/watch?v=aMNOKt0AaBQ
See time line at approximately 7:45
Baum tools no longer produces the P221 connecting rod holding tools.
Stromski Racing sells the P222 chain holding tool.
Does anyone have a P221 tool they would like to sell? Please let me know.
dannobee 08-02-2023 09:30 AM
Just make your own out of 1 inch banding material used to hold bigger stuff to pallets.
Literally free, it goes into the dumpster or recycle bin when it's cut off.
