H.G.P.'s Avatar
Question Dazed and Confused..Am I supposed to have intermediate shaft inner bearings???
I'm perplexed........I see online Pelican part # Intermediate Shaft Inner Bearings, 2 Per Car, 911 (1969-73), Each
T-101-435-70 $5.25
However!: .......
Wayne's book page 127 states..."If you have a stock early case (1965-1969), then the intermediate shaft rides directly in the metal of the case."
So I'm concerned if maybe I lost these bearings on dis-assembly, as my early case shows no sign of these, nor do I see these laying around anywhere.
How can I tell?
1969 911 E Coupe
"Little Bull" "Horse"
"H." Heart, "G." Gears, and "P" the Porsche
Old 12-14-2004, 02:25 PM
350HP930's Avatar
The case would have lock tabs in the bearing bore if it used an insert.
Old 12-14-2004, 04:04 PM
H.G.P.'s Avatar
OK, I think you're referring to the insert notches?
I went over the extensive digitals I fortunately took of dis-assembly, and found the one below. It appears that there is no inner bearing(s), as the adjacent crank bearing can just barely be seen to the right as a bright silver.
1969 911 E Coupe
Old 12-14-2004, 05:30 PM
Friend of Warren
It is quite easy to tell, lay the shaft in the cutouts and see if there is any room for a bearing to fit. From that picture it looks like a bearing would not fit in the space.
Kurt V
Old 12-14-2004, 07:03 PM
Author of "101 Projects"
Wayne 962's Avatar
Look for the tangs in the case, as shown on page 127. I think the catalog is written that way, because some of the late 1969 cases had the bearings? Factory documentation is weak on this issue...
-Wayne
Old 12-15-2004, 12:50 AM
