-   -   Wayne's Answer to the Question: What engine should I build? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/196921-waynes-answer-question-what-engine-should-i-build.html)
Wayne 962 12-18-2004 07:43 PM
Originally posted by NevenM
As you can guess I'd advocate Megasquirt EFI with the original intake for the following reasons.
I'm not sure how hot a cam you can run using the original CIS runners and MegaSquirt.
-Wayne
Wayne 962 12-18-2004 07:46 PM
Originally posted by 125shifter
Wayne,
After looking at your engine choices in the book, I wonder why the turbo engines are relatively stock. I.E. stock cams and CIS. I would think people that are building a turbo engine have a larger budget. In the next printing how about have a turbo set up for mid range power and a turbo set up for top end power. JMHO.
It's a pandora's box. Anytime you modify a Turbo, you're getting into more wear on the engine, and typically bigger $$$. Plus, there are no real easy Turbo upgrades. Some changes (like SC cams, etc), but nothing that will buy you a great amount of HP. Changing turbos themselves will alter the boost-on RPM, but then you sacrifice power elsewhere. The only way around the turbo lag problem is to install a 2nd turbo like they did in the 959.
So, keep it stock and reliable, or spend $$$ and decrease the longevity of the motor. Also, you hurt the resale value as soon as you start modifying a Turbo, because no buyer really knows what abuse the motor has taken...
-Wayne
NevenM 12-18-2004 07:49 PM
Wayne
As hot as you like, As you know the Cam limitation is not the CIS runners but the CIS metering system which does not like pulsing in the air flow. It would not be as free flowing as ITBs but much better than CIS. Which is a point, You would get some performance inrease in a CIS to EFI conversion simply because you are removing the CIS metering system which impedes air flow
Neven
Wayne 962 12-18-2004 07:53 PM
Wayne
Neven
That's not true. The CIS system is not an independent throttle body system, and cannot take a really hot cam, otherwise the engine will never idle correctly. It would be the same as running a hot cam with the 3.2 runners, which just doesn't work.
I just talked with Rick Clewett about this the other day in response to a question someone had.
-Wayne
emcon5 12-18-2004 08:31 PM
Wayne
Not exactly. There is some discussion of cam choices/limitations with single plenum here.
Tom
NevenM 12-19-2004 12:25 PM
Wayne
Ok its not entirely true, but then again does any engine with a 906 cam idle smoothly? But as I also pointed out you could then put in a set o.5f modified MFI ITB's for less than 1K which is much less that the 3+K required for a TWM 3006
Neven
dean 12-19-2004 02:51 PM
IMO not true. I installed headers, a large intercooler (that is for sale), 1 bar spring, and a K27 and got over 100 more hp out of a 3.0l 930. I think that is a lot for a few boltons.
I also don't think that is true.
-Wayne
echocanyons 12-19-2004 03:41 PM
Could you elaborate on this? Is the limiting factor air flow?
emcon5 12-19-2004 10:50 PM
It is the single plenum, See the link I posted up the page a bit.
Tom
echocanyons 12-19-2004 11:21 PM
Musta missed it before but I gave it a read,
Thanks Tom
