-   -   OUTER intermediate shaft bearing, hole or no hole? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/197843-outer-intermediate-shaft-bearing-hole-no-hole.html)
H.G.P. 12-21-2004 10:57 AM
My old outer intermediate shaft bearing has a hole in it's center, the replacement 996-101-137-80 does not. Should one be machined into the new.
Thanks!!!!
Wayne 962 12-21-2004 11:18 AM
Cases varied over the years. The rule of thumb is that if there is a hole in the case where the hole in the bearing should be, then there needs to be a hole in the bearing. Inner and outer intermediate shaft bearings are different too, with respect to needing the holes...
-Wayne
H.G.P. 12-21-2004 02:44 PM
-Wayne
This is the outer bearing.....there is no hole in the case. There is a hole in the intermediate shaft itself, forward of the sprockets.
