-   -   2.2 T, E or S (http://forums.pelicanparts.com/911-engine-rebuilding-forum/198548-2-2-t-e-s.html)
austin552 12-26-2004 10:19 PM
2.2 T, E or S
How can I determine if my 2.2l is an T, E, or S?
#'s etc??
http://memimage.cardomain.net/member...41_12_full.jpg
SteveF_911 12-27-2004 12:01 AM
Looks like a T to me.
Zenith carbs and black cowling.
Post the engine number to be sure.
austin552 12-28-2004 10:30 AM
engine #
If the engine is not original to the car, where can I find the 911#?
jluetjen 12-28-2004 01:36 PM
http://forums.pelicanparts.com/uploa...1104269790.jpg
campbellcj 12-28-2004 07:04 PM
You can also look for the cast iron barrels -- remember after 30 years many engines that began life as a "T" may not be one anymore, parts-wise. Displacement could be non-stock vs. the engine number as well.
snowman 12-28-2004 09:22 PM
Chris nailed it, after 30 years it could be anything. Look for outward signs, eg, cast iron cylinders, but the only way to know for sure is to tear it down and look at what you have.
austin552 12-29-2004 11:35 PM
Outward signs??
Cast Iron cylinders sounds pretty internal to me...
I will get the #'s out tomorow.
Thanks guys,
Austin :rolleyes:
vanwyk4257 12-30-2004 05:51 AM
Re: Outward signs??
Thanks guys,
Austin :rolleyes:
You can get underneath the car and you should be able to see the cylinders to tell whether they're cast iron or aluminum.
austin552 12-30-2004 10:15 AM
Engine #
Okay here it is:
*6112857*
I believe that is a "T"
Jim Richards 12-30-2004 11:41 AM
Yes, it's a 1971 911T engine.
viejopatron 12-30-2004 04:55 PM
Just for comparison, here's my 2,2 1971 911T Engine S/N 6115192.
http://forums.pelicanparts.com/uploa...1104454377.jpg
austin552 12-30-2004 10:16 PM
2.2l
Hey Gary,
Good to see I am not alone here, 2.2l wise...
Austin
