-   -   Crushed Copper shims!? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/198634-crushed-copper-shims.html)
hbrand 12-27-2004 02:42 PM
When disassembling my engine, I found the copper shims crushed and squized out at the bottom of the cylinders.http://forums.pelicanparts.com/uploa...1104190748.jpg
What can I replace those soft copper shims with??
One more please:
Are this Mahle or JE pistons? http://forums.pelicanparts.com/uploa...1104190937.jpg
tab tanner 12-27-2004 04:24 PM
Those are copper base gaskets I think the host sells them. There not very expensive. The piston look like a Mahle to me I may be wrong? But I don't think so? Get Wanyes book: How to rebuild and mod your 911 engine, All your questions will be answered
tab tanner 12-27-2004 04:25 PM
I just saw that you bought the book! Good going
Wayne 962 12-27-2004 04:43 PM
Offhand, they look like a typical Mahle cylinder, but I'd need more pics of the inside, etc to tell...
-Wayne
hbrand 12-27-2004 05:25 PM
Hello wayne
will post more piston pictures tomorro.
because of the crushed and slipped out cooper shims, the cylinders leaked at the cylinder head. So I gues i can only use the most thick once I can buy.
Can I post all the parts I need to order here and you give my the part numbers, or can your sales people handle zb ring set 92mm, 1.5x1.5x3mm, turbo cylinder head gaskets for 2.7 turbo
thanks, harold
kstylianos 12-27-2004 08:27 PM
Harold,
I wouldnt 'use the most thick once I can buy' as shim thickness needs to be selected to bring your deck heights to spec (you'll find this info in the book). The shims you posted are not typical....they appear to have been reused, installed incorrectly or the head studs possibly over torqued. In any case, not typical. You should be fine using the the correct thickness coppper shims, making sure your case and cylinder bases are flush and keeping the head studs torqued to spec.
BTW: Pistons do not apperar to be JE.
Jeff Alton 12-27-2004 09:29 PM
Them there look like Mahle's. not JE.
Wayne 962 12-27-2004 10:56 PM
There is no such thing as a 2.7 turbo. Is this that engine that you bought on eBay? Did you bolt a Turbo on it? With single plug and 11.5:1 compression? If yes, then it's no wonder the thing fell apart. Now I'm really confused.
Those cylinder base gaskets don't just get like that. This engine was beat to hell, potentially from detonation? Then perhaps the head studs pulled and the cylinders got loose and banged around the copper base gaskets. You just don't see that when tearing down an engine, unless the whole thing was imploding...
-Wayne
hbrand 12-28-2004 05:41 AM
I hate turbo engines.
My thought was if the head is leaking I can work on the surefaces and install some kind of head gaskets. some members said the turbos had them - but that would be 3.o ltr and they would not work on my 2.8 ltr
I do not know how this engine was run by its former owner, all I want this engine to be is a fast long lasting stret engine.
thanks, harold
cstreit 12-28-2004 09:22 AM
WHat's with the cast looking surface on those pistons though, haven't seen that before on a Mahle piston.
hbrand 12-28-2004 12:00 PM
More piston pictures. Mahle or J E??http://forums.pelicanparts.com/uploa...1104267433.jpg http://forums.pelicanparts.com/uploa...1104267479.jpg http://forums.pelicanparts.com/uploa...1104267520.jpg http://forums.pelicanparts.com/uploa...1104267567.jpg
Wayne 962 12-28-2004 12:06 PM
thanks, harold
If this was the other motor you're talking about, it's not ever going to be a long-lasting engine, if you keep it in this config. 11.5:1 - nothing long-lasting about that, particularly with a magnesium case.
Take a look again at some of the chapters in the book, and that should help you decide what to do.
These pistons look forged to me - they look very much like Mahle RSR style pistons. They don't look like any JE pistons I've ever seen. The JE pistons I've seen are all machined across the top of the cylinder. These tops (minus the pockets) were forged.
-Wayne
hbrand 12-28-2004 01:15 PM
Thanks wayne, first will determine the compression ratio I have and the zero in for about 10.
Will post nice pictures soon.
Thanks, harold
Wayne 962 12-28-2004 01:20 PM
Thanks, harold
If this is that 2.7 engine, I would assume nothing and measure everything...
-Wayne
snowman 12-28-2004 08:35 PM
Something banged the hell out of these copper spacers. Nothing std or within spec could cause this type of damage. And it is DAMAGE, big time. Do not put this thing back togather without finding out exactly what caused this.
rcwaldo 12-29-2004 09:04 PM
Looks like 'fretting' caused by loose cylinders (pulled headstuds or undertorqued head nuts).
snowman 12-30-2004 03:40 PM
rcwaldo stated the most likely cause.
Question- could this also be caused by pre ignition? In other words head studs pulled or stretched due to extreem pressure generated by pre ignition due to high compression ratio. See Waynes comments above.
In any case I would use only copper shims on rebuild. Thick copper shims are available if needed.
Long lasting street engine? CR on a Porsche is effectively about 1 point higher than on a water cooled engine according to Bruce Andersons book. Using premium gas with an ignition that includes knock detection would seem to limit the CR to 9.8:1. Otherwise without the knock detector to maybe 9.3 to one max. Thats for long lasting.
Your case almost certainly needs to be re decked as well.
Copyright 2018 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
