Will these fit on my 3.0L
No response from the technical forum so I thought I would post here.
Will 993 heat exchangers fit a 3.0L SC motor? I know the passenger side exchanger will need to be cut at the ports, rotated and re-welded but I was wondering about the spacing between the ports? |
Well, 3.0L heat exchangers won't fit unmodified on a 993, so I would assume that the opposite wouldn't fit either.
Anything can be made to fit though with a torch and welder... -Wayne |
Wayne,
I understand what you are saying but, if the 993 passenger side exchanger had the three inlets that mount to the heads cut off and rotated then re-welded, wouldn’t they then fit? I know that guys have done this on 964 motors, so if they can do that for the 964 motors, then wouldn't the same exchangers fit on a 3.0L? Do SSI's from a 3.0L fit on a 964 motor, I know the tube size wouldn't be correct for best performance but will they bolt up? What I am wondering is if the spacing for the exhaust ports to bolt on the exhaust (headers/heat exchangers) is the same for a 3.0L, 964 motor and a 993 motor? Thanks SmileWavy |
I'm not sure...
-Wayne |
-Chris |
Thanks guys,
Let the new project begin.. MUHAHAhahaha http://www.pelicanparts.com/support/...amingdevil.gif |
| All times are GMT -8. The time now is 12:43 AM. |
