-   -   What is the fix for this? (photo) (http://forums.pelicanparts.com/911-engine-rebuilding-forum/198998-what-fix-photo.html)
VaSteve 12-29-2004 07:53 PM
In taking off the fan shroud on the left (driver's) side, I snapped off two of the bolts. After drilling them out and using one of those reversing bits, I was able to get all of the bolt out. It appears that I damaged the threads. What is the fix for this? Can I just run a tap and die set over it to rethread the hole and use the same size bolt? These bolts only hold down the shroud so it's not really carrying a load or any vital parts (like the ones that hold on the throttle linkage).
I am not completely disassembling the engine so I'm avoiding taking the heads off and to the machine show for this alone.
Thanks!
(Sorry the photo kinda sucks)
http://forums.pelicanparts.com/uploa...1104378791.jpg
addictionMS 12-29-2004 09:04 PM
I would think you are ok, I have a few of those bolts missing and I have not suffered any, if in doubt, you can always timesert it, but I think that would be overkill....
Jim
Jay Auskin 12-30-2004 12:00 PM
As you said, you're just holding the shroud down. Just do as you are thinking (or as Bietendorf suggested to take it a step further), and check it periodically. This isn't a critical fastener. You should be fine...just check it after a few runs.
viejopatron 12-30-2004 05:08 PM
When I buggered some M10 threads, I got a repair kit from McMaster-Carr. The kit includes a drill bit, tap, insert installer and inserts. Go online to the M-C site and enter "Thread repair" in the search field.
http://www.mcmaster.com/
VaSteve 12-30-2004 05:33 PM
Just to wrap up. I got lucky, I was able to chase the threads with a tap kit. There were enough threads left at the bottom to hold in the bolt. Thankfully, it was only a shroud bolt.
http://www.pelicanparts.com/support/smileys/wat6.gif
