-   -   Broken Chain Guide - Mechanical Tensioners (http://forums.pelicanparts.com/911-engine-rebuilding-forum/199623-broken-chain-guide-mechanical-tensioners.html)
triplesn8s 01-03-2005 05:12 AM
Techies,
Upon disassembly I found the drivers side upper tesioner in pieces. Amazing that the motor still ran well. Lucky it didn't slip timing (I have only driven it home from where I bought it.) At least I know where the funny flapping sound was coming from.
Can I assume I have a bad tensioner on that side?
With all the talk of tensioner failures regardless of style I was thinking of going with mechanical tensioners. I don't mind a little periodic maintenance and the savings are big allowing expenditures in other areas, like chains & sprockets.
Can anyone correctly describe the setup & adjustment procedure for mechanical tensioners? Any brands to recommend for any reason?
All feedback is welcome.
Bill
David 01-03-2005 07:18 AM
Mechanical tensioner questions have come up several times over the years. A search should yeild lots of info.
Wayne 962 01-04-2005 01:14 AM
You mean solid tensioners? It's a great way to destroy your engine - read up on this in the Engine Rebuild Book.
I recommend the Carrera Chain Tensioners. Nowadays, they are the same price as the older spring-loaded ones...
-Wayne
triplesn8s 01-04-2005 05:30 AM
I bought rebuild kits for my tensioners some time ago. I will likely go that way with the locks for back up.
I heard there is a difference between the OEM rebuild kits and the aftermarket. Any comment?
BTW, I now your book for procedures, great book.
Thanks,
Bill
