2,4S wristpin length ? will machine a T-pin
What is the length of the 2,4S mahle piston wristpin? and wath sort of lockingclip shall I use? I have and old set of pistons but the wristpins are gone, the machineshop will make a new set of a set of T- piston pins.
Thanks //Henrik SWEDEN |
Just find a used set - these never really wear out, and you can probably get them for free from a helpful Pelican board member.
-Wayne |
I have a set of wristpins from a T engine and will "cut! them to the correct length to fit in the S-pistons.. |
Is there anybody that have a S - 84mm wristpis that could messure the length?
The 2.4 T and S (and 2.2 T,E and S for that matter) all used the same wrist pins. They should be interchangable without any trouble.
Also you can get the wire clips from out host. |
Im not sure, but the Mahle 89mm and 90mm use for 2.5 and 2.7 upgrades both had 22x58mm wristpins
| All times are GMT -8. The time now is 01:53 PM. |
