-   -   3.6 question (http://forums.pelicanparts.com/911-engine-rebuilding-forum/200030-3-6-question.html)
Jeff Alton 01-05-2005 09:21 AM
3.6 question
Can early 3.6 heads and cyliners be modified for the sealing ring or do I have to get new cylinders?? Also, who would you recomend for this service on the west coast?
thanks, Jeff
ChrisBennet 01-05-2005 11:55 AM
I can't find it now but I remember seeing a post where someone did a mod to add an O-ring (there was a picture). I think it involved removing material from the outside of the cylinder to sandwich an O-ring between the outside of the cylinder and the head.
I was leary about removing more material from an already skinny cylinder sealing surface so I went with the later cylinders (good used) and updated the heads.
-Chris
Jeff Alton 01-05-2005 02:01 PM
Thanks Chris, I was hoping you would provide an answer!!
Jeff
