What's with "six" "items" in ring land per old piston? New with 3
Old pistons had 6 items per piston.
A. One upper comp. ring, B. two items in second ring area, and finally C. 3 items in the third land. New rings have only two upper, and one "spring ring". Question: with the new third "spring" oil ring, how does the spring install with the ring? Does the spring stretch with the ring during install? Thanks Six came out each piston shown below:
1969 911 E Coupe "Little Bull" "Horse" "H." Heart, "G." Gears, and "P" the Porsche |
are they goetze rings? deves would be last on my list.
Does the oil spring expand along with the ring? Or does the spring have to be rolled down the piston with the ring? ( The two compression rings look easy.) Thanks Kirk
Author of "101 Projects"
See the instructions in the engine book - the oil ring is installed with the spring inside...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
Banned
Good point. Wayne I have a legit crititism of your book. One I hope you can fix if you reprint it, MAKE THE FIGURES, PICTURES, LARGER! Please.
