Sammy - your too kind, I will pm you if I end up trying to do it my self.
dd74, great option! I had not thaugh of that, however I think I found some very reputable leads of folks that could do it locally, I will look in to your sugestion if I have to go with plan B |
Contact me off line and I can give you a copy of the Factory workshop manual if you want to read through it and see if this is something you want to tackle on your own. It is not that hard, just requires a little planning, patience and the wisdom of the knowledgable people on this board. Contact me anytime off line and I will help where ever I can.
Pacwestperformance@telus.net Cheers, Jeff |
Ralph - your PM box is full
Ralph P.S. - It's really tough for Steve and I to figure out an estimate for you at this point because we haven't seen the motor and are just basing on what you have told us. I think the best way is to do a straight labor quote for complete diassembly and reassembly and then let you source the parts. I can help you there as well. If you want to help with the assembly and take pictures, I'm sure that can be arranged as well. I'll send you my excel file and phone number tonight and you can take a look and call me. You don't need to do nearly as much as I did for the 3.5L, the biggest expense is going to be new pistons & cylinders (if you need new 95's or if you want to go to 98's) and the machine work to rework the heads, rods, crank, rocker arms, etc. The standard rebuild parts aren't very expensive, it's the performance parts and "upgrades" that make the costs increase so dramatically. Since you are working on a tight budget, I would do a standard 3.2L rebuild with new head studs, rod bolts, upgraded cams, upgraded valve springs, extrude honed plenums, pre-muffler, sport muffler and Steve Wong chip. You'll get a decent power gain over the stock 3.2L with the proper updates that should get you another 100K easily. Ollie's can do all of the machine work and they have their own phosphorous bronze guides that will far exceed the original factory units. You may or may not need new valves, you won't know for sure until the heads are disassembled. My excel spreadsheet lists all of the Porsche part numbers for the various parts needed or at least inspected for a 3.2L rebuild, you can just plug in your parts cost from Pelican or whomever you are going to source them from to get you an idea where you are at. |
| All times are GMT -8. The time now is 07:27 AM. |
