-   -   Webcam 158 grind (http://forums.pelicanparts.com/911-engine-rebuilding-forum/200805-webcam-158-grind.html)
}{arlequin 01-10-2005 08:44 AM
Webcam 158 grind
What kind of specs does this cam have? Is it viable in a carb street motor w/ 9.8:1 cr? Looks like it may be a bit on the wilder side? Does this cam lose all the torque in favor of high-rev breathability?
thanks.
ChrisBennet 01-10-2005 05:04 PM
Webcam's web site lists a 158r but not a 158.
I'm probably having another Senior Moment but for some reason that # seems familiar - like they were in my '86 Carrera before I went to 964 cams. I think "158" was stamped on the end of the cams.
-Chris
TimT 01-10-2005 05:09 PM
I have the 158 in my 911, its a nice cam
}{arlequin 01-11-2005 07:23 AM
Thanks Chris.
Tim,
Can you give me more details about your engine config?
ChrisBennet 01-11-2005 07:43 AM
If you talk to Webcam let us know what she tells you.
-Chris
}{arlequin 01-11-2005 12:06 PM
update: from JD/camgrinder I found out that a 158 is a "hot" SC/CIS cam and 158R is a carb cam.
From *her*, I found out that a 158R is their 2.7S cam with valve lift of .450int and .400exh, for duration .232int and .222exh, between 3.0-3.3mm with .10mm lash
Does that make sense?
ChrisBennet 01-11-2005 01:31 PM
Cut me some slack, I'm senile remember? :D I forgot Camgrinder was Webcam, not Elgin. When I called Webcam a few years ago I spoke to a woman.
I think the cam timing setting value was the same for the 158 as the stock Carrera cams.
-Chris
}{arlequin 01-11-2005 02:05 PM
LOL, no no, Chris, you got it all right. (It didn't come through in the text, but I was actually stressing the fact that it WAS a "her".... caught me by surprise b/c it matched your statement ;))
So no matter how long ago that was, it's still a "her" (which is a nice thing to hear, kinda like those girls on 5th Gear/Mythbusters :D)
ChrisBennet 01-11-2005 04:48 PM
Oh, good, thought I was having another Senior Moment there.
Car savvy girls are neat.
I was visiting a friend at his auto repair shop this summer. He employed a girl (college student I think) behind the front desk. While I'm waiting for my friend, a customer tells the girl that his BMW trunk lock isn't working right, unlocks after he locks it or something like that. I was so surprised when she started telling him that lock used an electric/pneumatic latch actuator made by such and such and it was also used by Mercedes. I think she even told him what the problem was.
I said to her "I'm in love! Can you say pneumatic actuator again?"
-Chris
camgrinder 01-11-2005 05:07 PM
I am not Webcam or Elgin.... I am Dougherty Racing cams now. :)
Carrera3.5L 01-11-2005 06:11 PM
You probably spoke to Laurie Dunlap over at Web-Cam. She is one of the owners...;)
Ralph
TimT 01-11-2005 07:03 PM
sure, Im using the 158r in a 2.2L
Its either 9.8 or 9.5:1 cr (Id have too look at my notes)
Twin plugged
930 oil pump
Ports opened to S+ specs
Ti retainers and keepers
Aase springs
TWM throttle bodies
tall PMO manifolds
EFI
carrera tensioners etc.
When I first built the engine I dynoed the car, and with the cam timing I used the torque power fell off at about 6500 rpm. Ive recently done a top end rebuild on the engine and timed the cams so power falls off at about 7000 rpm.
Im at work right now, but I have some dyno sheets somewhere
This engine is alot of fun in a car that weighs less than 2000#
