-   -   Thermostat as seen through the oil cooler holes I should see ? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/201127-thermostat-seen-through-oil-cooler-holes-i-should-see.html)
H.G.P. 01-11-2005 11:29 PM
With the oil cooler off, just wanted to confirm that I should see one of the open staggard notches in the thermostat, when looking through the upper cooler holes.
And is there a technical term for the staggard "open notches" in the thermostat?
ChrisBennet 01-12-2005 07:31 AM
After all these years I just learned that the oil cooler thermostat is "idiot compensating" - the studs are offset such that you can't put it in backwards.
-Chris
H.G.P. 01-12-2005 04:00 PM
-Chris
Yes, I read about that awhile ago in the Haynes manual, but because I've not installed the thermostat since some time ago, I could not recall the tightness of the fit.
I still would like to know if one of the staggard "slots" can be seen through the oil cooler hole when the cooler is off, as I have my cooler off and this would make nice double confirmation.
ficke 01-12-2005 06:40 PM
There was a very good thread earlier on thermastats, and there failures, I checked mine in boiling water like so well described with pictures in that thread , and found it to be inop. brought new checked in boiling water worked fine> Fritz
H.G.P. 01-12-2005 11:00 PM
Thanks Fritz.
