-   -   Riddle...or "What's not in Wayne's book" (http://forums.pelicanparts.com/911-engine-rebuilding-forum/201210-riddle-whats-not-waynes-book.html)
H.G.P. 01-12-2005 11:53 AM
Tops........Tops...........Tops
"Joker springs backwards to the Crown"
"Oil to the Crown"
"2 to the 2"
"Three to the E"
Tops.......Tops.......Tops
adomakin 01-12-2005 01:03 PM
what the Łuck?
dtw 01-12-2005 02:34 PM
You need to ventilate the garage when working with acetone and other cleaning supplies.
Did you ever measure your main bore.
Doug Steinel 01-12-2005 05:09 PM
comeon guys, give the man a break. Some porsche people are literate.
H.G.P. 01-12-2005 07:56 PM
Any takers?
Hint #1: Install (ation) of.........
Tyson Schmidt 01-12-2005 09:23 PM
Sounds like how to install rings properly.
Wayne 962 01-12-2005 10:12 PM
*Everything* is covered in my book.
-Wayne
H.G.P. 01-12-2005 10:43 PM
http://forums.pelicanparts.com/uploa...1105596534.jpg
Just for my own thinking, I wanted a checklist to install my particular new rings the same way.
I wanted to be sure the oil spring break ("Joker") stayed opposite ("backward") of the ring (which surrounds and "holds it) gap holding it. (The spring reminds me of a joker's hat.) The oil ring gap staying toward the top ("Crown, in this case, meaning cooresponding to the piston valve large relief cutout" 4-7 Wayne's book)
The second #2 ring, on my pistons, the ring gap I coorespond toward the number 2 side of the piston, which is stamped on the right side on my pistons. So 2 gap to the 2 side.
And then the #3 top comp. ring on my pistons, the gap cooresponds to the E (stamped on the piston) left side of the piston, which is opposite to the 2 ring. So "#3 to the E side.
Last, I double check that all rings top stampings face the "top" of the piston. 4-3 Wayne's book. (photo above does not show the bottom small relief cutout due to the magnifying)
For my own dazed thinking.......................
:D :D
adomakin 01-13-2005 10:54 AM
flipping eck!
10 points for effort anyway!
Henry Schmidt 01-13-2005 11:17 AM
Rings rotate when the engine runs so aside from installing the rings up side down you can hardly make a mistake.
Space the gaps so they don't all line up and you're go to go.
snowman 01-14-2005 06:11 PM
Great!!! someone finally outdid my most outrageous post.
audi2.7t 01-14-2005 08:48 PM
-Wayne
hmmm, how about disconecting the clutch on a G50 for engine removal ?, as far as I see it only covers a cable clutch. (101 projects)
p.s.
Judging by the amount of posts from HGP regarding your books maybe you could have him proof the next one...:D
Wayne 962 01-14-2005 10:31 PM
Hmmm, I'll leave that one alone. To clarify - everything is included in my "Engine Book." The 101 Book is a compromise book that couldn't possibly include all of the info that you would need for all cars 1965-89.
Henry and snowman are right - the rings to rotate in the grooves when the engines are running. Still, it's best to start them out opposite from each other with the oil ring on top.
-Wayne
