-   -   How to re-assemble oil pump? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/203246-how-re-assemble-oil-pump.html)
belling 01-25-2005 03:46 PM
I took apart my oil pump (1970), and now when I tighten the nuts it seems to bind. I've heard of other people having this problem, is there some magic to getting it to spin freely?
Tim Walsh 01-26-2005 04:09 AM
I belive the experts say don't disassemble it and if you do, mark the orientation of the gears so that it can be put back together exactly right.
My sugestion is to just pick up a later oil pump (76?-89) since I'm assuming you're doing the oil bypass mod and the later pump has a larger pressure side.
belling 01-26-2005 12:41 PM
I wasn't planning on doing the bypass upgrade, so I guess I'll have to find an old oil pump.
As soon as I pulled it open I knew I shouldn't have done it. :P Curiosity killed the cat and all.
ChrisBennet 01-26-2005 02:48 PM
C'mon there's something like 4 parts isn't there? I'd try the 16 combinations before I gave up...
-Chris
belling 01-26-2005 03:14 PM
I've got the parts right. With it all closed up and the nuts finger tight, it spins fine. Tightening down the nuts and it gets hard to turn. I'll keep playing with it...
NevenM 01-28-2005 05:10 AM
There is generally no problem with disassembling and recon oil pumps. You can reset the end clearance by 'glass plating' the housing. I'd firstly try and determine what is binding, ie are both sets of gears tight, Try assembling it with the top and then the bottom set of gears, if they spin freely then the end play is ok, it is the engagement of gears. Then 'incrementally' assemble the pump, do the pressure one first and then the scavange one (which has 2 gears IIRC). It is also possible to assemble the pump incorrectly (which my engine builder did!) with the shafts transposed (I noticed this as I fitted it to the crankcase)
HTH
Neven
Jim Richards 01-28-2005 05:28 PM
it'll turn better with some oil, even using WD40
snowman 01-28-2005 10:07 PM
I have dissassembled an early oil pump, put it back togather several differen't ways, including the exact way it was taken apart and found NO difference. Anyone else found the same?
belling 01-30-2005 08:35 PM
I got it back together fine. There was some grit in the holes the little fitting posts push into, and it seems like they were deforming the case a bit. I cleaned everything up really well, oiled it up, and it turns fine. I diddn't change which gear goes where, or which way the gears go on the shaft, but I have no idea exactly how the gears were meshed. It doesn't seem to matter.
Thanks for the help!
snowman 01-30-2005 08:40 PM
ITs supposed to make some kind of difference, but in the case of an oil pump does it really? Anyone with some kind of long term experience on this subject?
126coupe 02-01-2005 01:39 PM
$175.00 came from one of my race engines works greathttp://forums.pelicanparts.com/uploa...1107297547.jpg
