-   -   Increasing compression? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/203393-increasing-compression.html)
crashmy911 01-26-2005 03:39 PM
Is it possible to increase my compression just by shaving the heads. I have a 1978sc and would like ot do a few more mods. Maybe go to twin plugs also.
Carrera3.5L 01-26-2005 03:53 PM
Re: Increasing compression?
Yes, milling the heads will increase the compression ratio.
Ralph
crashmy911 01-26-2005 03:55 PM
How much could I get away with on a stock sc. And go to twin plugs. Still have cis and engine has 964cams .
ChrisBennet 01-26-2005 04:17 PM
You won't need twin plugs for the small compression increase you would get from milling the heads. If you have the budget for twin plugging (an expensive proposition) I'd spend it on 98mm P&C's and make a 3.2 instead.
-Chris
