-   -   Re-Chromed Crank? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/203520-re-chromed-crank.html)
CreatuR 01-27-2005 05:29 PM
Re-Chromed Crank?
Hello again. I am in the process of locating a crankshaft for my '89 930. I've had one offered to me that has been "re-chromed". Any ideas what that means?
Thanks!
camgrinder 01-27-2005 08:40 PM
Sounds like the crank had a failure. Instead of welding the journal they hard chromed it.
The preferred method is to weld the journal, grind the crankshaft and nitride. Nitriding stress relieves the welded area and rehardens the entire crankshaft.
Call Armando at C.C.R, 650-342-0568 he specializes in Porsche crankshaft work and can give you the details.
snowman 01-27-2005 09:25 PM
Yeh, Porsche cranks are not Chromed.
CreatuR 01-28-2005 07:02 PM
Thanks John. I'll give Armando a call.
David 01-29-2005 04:59 AM
I'd look for one that hasn't been repaired. It shouldn't be much more $ but it would be more reliable.
350HP930 01-29-2005 06:41 PM
Good standard 930 cranks appear to be going for about $1500 nowadays.
CreatuR 01-29-2005 10:19 PM
Heh, if you know of one please let me know. I haven't found one yet.
