rotorhead's Avatar
Cam Timing Question
I am timing the cams on my 930 (glad I have Waynes Book) I set them up accurately but when I removed the vicegrips and replaced the tensioners the timing moved slightly due to the change in timing belt tension.
The range according to the manual is 0.65 - 0.85 (0.70 being ideal). With the clamp in place I had 0.70 on both left and right. With the tensioners installed I have 0.77 left and 0.71 right.
Do I need to redo the timing?
2008 BMW 320i
2006 Mercedes ML320
2004 Mercedes ML270 cdi
1998 Porsche Boxter
1988 Porsche 930 Targa (sold)
Old 03-27-2005, 04:14 PM
camgrinder's Avatar
A rough rule of thumb is .3mm is one degree of camshaft timing. I would say your engine is within 1 degree of ideal.
John Dougherty
Dougherty Racing Cams
Old 03-27-2005, 05:10 PM
rotorhead's Avatar
Thanks for the quick reply John, this bbs is awesome.
One interesting thing I noticed was the difference in timing when turning the crank clockwise to the TDC mark against turning it past the mark then turning it back CCW. There was around 0.05 difference, I figure this is the amount of play against either face of the teeth on the cam sprocket.
2008 BMW 320i
2006 Mercedes ML320
1998 Porsche Boxter
Old 03-27-2005, 05:16 PM
camgrinder's Avatar
Yes , the slack in the chain will give you different reading. When setting the camshaft timing in any engine the chain should be preloaded by turning the engine in the direction it will be running.
John Dougherty
Old 03-27-2005, 05:30 PM
