-   -   what woul you use (http://forums.pelicanparts.com/911-engine-rebuilding-forum/204353-what-woul-you-use.html)
philippeF 02-02-2005 01:03 PM
what woul you use
to clean a 2.7RS mag case ?
Philippe
AFJuvat 02-02-2005 06:31 PM
Soap, Hot water, and engine degreaser.
AFJuvat
NevenM 02-08-2005 02:22 AM
Philippe
Sometimes you need to be a bit harsher, I made a 'spit' out of a piece of 10mm steel rod but hacksawing a slot in the end, I put this in the chuck of a flexible drive off a power drill and in the slot you put bits of scotchbrite type pads, You can also round of the end of the rod with a file, This is great for getting the crusty bits off
HTH
Neven
Philippe
Oops meant 'split' not 'spit'
