-   -   whats the best Cam for a 3.5L Mahle Conversion (http://forums.pelicanparts.com/911-engine-rebuilding-forum/205537-whats-best-cam-3-5l-mahle-conversion.html)
Pete_B 02-09-2005 08:47 AM
I am in the middle of converting my 3.2 to a 3.5L using Mahle Pistons and Barrels. I will also be using a Motec M48 Pro to manage the engine as well as throttle boddies.
Whats the hotest Cam grind I can use while retaining street drivability and smooth idle. My intention is for the car to be a fast road car with occassional track day use. I'd like the power to be wide ranging rather than only available at high revs like the early 'S' cars.
Any help very welcome.
Pete
asphaltgambler 02-09-2005 08:52 AM
PM John (the camgrinder) for his rec.
Tyson Schmidt 02-09-2005 08:37 PM
The Mod-S cam is awesome. It is the early S cam, but with the lobe centers widened. It really has a nice broad power band, and still has the nice build up of power as the revs rise. It's a terrific cam for bigger motors.
I assume your compression ratio will be somewhere above 9.8/1?
jmz 02-09-2005 08:46 PM
second the MOD S cam. I have them on my 3.0 and they work well.
Pete_B 02-10-2005 01:00 AM
thanks guys.
my compression ratio is 10.3:1. Hence the twin spark!
The Mod-S sounds like its worth checking out. Does it give a smooth idle and provide good drivability on the street at llow reves. Also, do you know the dwell, lift and lobe centre information from the mod-s cam. Also, where I can it from? Is it a regrind or billet build from scratch?
Cheers
Pete
jmz 02-10-2005 06:15 AM
Elgin is where I got mine. Re-Grind off the SC cams
Tyson Schmidt 02-10-2005 01:32 PM
Originally posted by Pete_B
thanks guys.
Cheers
Pete
Yes, the idle is smooth, and great driveability. The specs are the same as an early S cam, but something like 110 or 112 degree lobe centers instead of 97 degrees for the early S cam.
I think Web-cam sells them outright. Maybe Elgin can re-grind your cams, but I'm not sure if there is enough meat on stock 3.2 cams to get the lift and duration.
KobaltBlau 02-10-2005 04:23 PM
send a message to the user "camgrinder" on this board for details. he will be very very helpful.
Shuie 02-10-2005 08:32 PM
Send Paul Thomas a PM also. I think he is running a GE80 in his twin plugged 3.5 MFI motor. IIRC, this is a pretty aggressive cam.
Pete_B 02-11-2005 02:10 AM
thanks guys this is really helpful. Will send PM's and let you all know how I get on.
Cheers
Pete
