Do i need to take out End caps on Camshaft housings to clean?
While cleaning my engine tonight, the following question arose.
My camshaft housings were pretty dirty and a lot of sand and dirt covered them. I cleaned them with degreaser and petroleum.
They are pretty clean now, but there's one spot where it's nearly impossible to clean with cloth and that's the central bore with the end cap in there.
Do you need to take out the end cap and clean and use a new end cap or are there other methods to clean this area?
Thanks for your info.
Old 02-13-2005, 11:40 AM
My left side is easier to clean as it has no cap (drive for mfi pump). So it is probably worthwhile to tap the cap out. I bet it can be reused. While you are in there, do pull the spray bars, there might be some dirt in there also.
Peter
'13 981S
'73 911T
'05 996 4S cab, now gone
'70 911S Targa, now gone
Old 02-13-2005, 12:25 PM
350HP930's Avatar
Hell, I went as far as removing the spray bars, but thats just probably my OCD at work.
Old 02-13-2005, 07:10 PM
Banned
snowman's Avatar
I agree remove everything, spray bars included. To replace the plugs on the spraybars I would suggest tapping the ends and screwing in a plug rather than pressing in a new Al plug.
Old 02-13-2005, 08:47 PM
Irrationally exuberant
ChrisBennet's Avatar
The part number of the "freeze plug" style end of cam cap is
930 105 161 00
For the spraybars, I just remove the plugs and clean the spray bar in place. The factory spray bar plugs are cheap. Part # 901 105 379 00
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i 245K miles!
Old 02-14-2005, 07:17 AM
Air Medal or two
afterburn 549's Avatar
I am with snowman.Makes it ez next time.....just make sure it is a "pipe plug" or she will leak (tapered)
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 02-16-2005, 09:17 PM
CEO CEO is offline
CEO's Avatar
Send a message via AIM to CEO
How do you remove the spraybars. Just tap the end cap untill it pops out on the other side.
Kenneth
Silver 81' Targa
Old 02-22-2005, 05:13 PM
Air Medal or two
drill tap and pull
Old 02-22-2005, 05:36 PM
Look inside the spraybar before you pull. On 964's at least, there is a locating pin in there that would keep you from pulling the spray bars out (unless you removed the pin first). I don't recall if the earlier motors have this setup.
-Chris
Old 02-22-2005, 06:09 PM
Air Medal or two
Yes its a bolt with a indexing pin that goes threw a hole.
Old 02-22-2005, 08:45 PM
