-   -   Cylinders (http://forums.pelicanparts.com/911-engine-rebuilding-forum/206537-cylinders.html)
Mrame 02-15-2005 07:10 AM
Cylinders
Hi Guys,
I have an 82 SC with a 3.0 L engine. I want to replace the PC's and Cylinders. Will these work in my engine. http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=7954500765. Is this a good price for these?
Mike
ChrisBennet 02-15-2005 07:45 AM
Yes, the will fit and the price is great IMO. The compression ratio may be a little high depending on the fuel you have available.
-Chris
Mrame 02-15-2005 07:54 AM
Chris,
Thanks for the reply. The cylinders that I have has a groove for a sealing gasket . Will this pose a problem with the heads?
Mike
ChrisBennet 02-15-2005 08:01 AM
Originally posted by Mrame
Chris,
Mike
As long as your heads have a nice flat sealing surface you should be fine. '84-89 Carrera's lacked a sealing ring.
-Chris
