911mot's Avatar
Is it OK to heli-coil an exhaust stud?
Ive been having major grief with one of my exhaust studs.
It broke becuse I didn't heat the nut so I center punched and drilled out the remains. Started OK with a 3mm pilot and the gradually went up .5mm in drill size till I could see the original thread. Great I thought, now I'll just clean it up with a thread restorer. I must have been rushing because I managed to snap it off in the head. Cue wrench being launched at high speed into garden. Next day I drilled out the broken bit and got to a similar stage as last time, only this time I tapped the hole with an M8 tap. Screwing the new stud in seemed OK at first but as soon as it 'bit' and I applied some torque it stripped the thread.
So what should I do now? Should I tap it slightly larger for a bigger stud, or will a heli-coil insert get me out of this one?
Thanks for your advice.
1984 3.2 Carrera
Impact Bumpers on track: http://www.youtube.com/watch?v=C4qbFNkdD2o
Old 02-17-2005, 02:44 PM
a helicoil or timesert should work fine. i like timeserts, personally.
206 637 4071
Old 02-17-2005, 03:04 PM
911mot's Avatar
OK thanks. I've already got the helicoil so I'll try it first and if I bugger that up, a timeserts it will be..
Just been out to look and realised (I think) my second mistake. I used an M8 tap. Shouldn't that have been an M8 x 1.25??
1984 3.2 Carrera
Old 02-17-2005, 03:15 PM
yes.
206 637 4071
Old 02-17-2005, 04:20 PM
911mot's Avatar
Me ---->
R.O.W-->
1984 3.2 Carrera
Old 02-17-2005, 05:01 PM
ChrisBennet's Avatar
Am I missing something? It would be an unusual "M8" tap that wasn't M8x1.25. A Timesert will be a better solution. See if you can borrow someone's 8mm set.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i Coupe
Old 02-17-2005, 05:55 PM
Banned
snowman's Avatar
A helicoil is a lot cheeper, smaller than a time sert. If the installation succeeds, great. If not theres still space to drill it out more and put in a time sert.
I did an entire mag case with helicoils. There were a couple of spots where I had to use timeserts, because the helicoils failed, mostly due to operator error. But arn't 2 chances better than one?
Old 02-17-2005, 10:39 PM
911mot's Avatar
That's what I thought. I just went and bought an M8 tap on its own.
But after the thread got damaged I looked for a tap and die set on the net and found they come in M8 and M8 x 1.25
FWW I can't screw a new barrel nut up the M8 tap. I'll try the 1.25 tomorrow when it arrives
1984 3.2 Carrera
Old 02-18-2005, 12:21 PM
Banned
snowman's Avatar
If you are putting in a helicoil or timesert you will not be using a std tap. You need to be using the one for the helicoil or the timesert that accepts the 8 x1.25 mm stud.
See the helicoil or timesert tech info for correct sizes.
Old 02-18-2005, 07:08 PM
1fastredsc's Avatar
Send a message via AIM to 1fastredsc
Helicoil should be fine, ones i've had are all some really hard type of stainless steel, which i'm sure won't have any problems with the localized heat.
2007 Mazda 3 hatch
1972 Porsche 914 roller with plenty of holes to fix
Old 02-18-2005, 07:14 PM
