What temp to heat my steel wheel gear!!
While tearing down my engine, it became apparent that I needed to replace the steel wheel gears on the intermediate shaft. They where very worn and actually 2 teeth where missing...
In wayne's book he explains how to put the Crank gear back on the crankshaft by heating them up in oil to let the metal expand before refitting. He also mentioned specific temperatures for each gear.
To what temperature do I heat the steel wheels before fitting them on the int. shaft?
Thanks for your help.
Old 02-23-2005, 09:07 AM
David's Avatar
The coefficent of thermal expansion of steel is about 6.3 x 10^-6 per degree F. So if the diameter is 3/4" the expansion at 300F would be 6.3 x 10^-6 x 3/4" x 300 = 0.0014". I don't know the diameter of the shaft or the fit, but you could calculate how much you need to heat it to have a 0.001 to 0.002 clearance when you slide on the gear. I wouldn't heat it over 500F for fear of softening the material.
Old 02-24-2005, 07:58 AM
a press is generally used for those. on and off.
206 637 4071
Old 02-24-2005, 08:14 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
If you're quick then you can just heat them up in a bath of oil and drop them right on. I replaced mine, and one went on nicely, the other had to be pressed on.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 02-24-2005, 08:17 AM
I heated mine in the oven to 300 degrees and put the shaft in the freezer. I pounded the gear on with a big socket and a hammer. It went on with no problem. If it gets stuck you can always take it to Napa and have it pressed on.
-Andy
Old 02-24-2005, 11:03 AM
Bird. It's the word...
Fishcop's Avatar
I used a friend's press to get them off and Eagle's method to get them on...
John Forcier
Current: 68L 2.0 Hotrod - build underway
Old 02-24-2005, 11:21 PM
