Can piston squirters be disabled/enabled?
Some experts say the Nikasil cyls do not break in properly with piston squirters thus don't recommend them, so rather than removing them altogether as I would like to use them after breaking in, I wonder if a disabling/enabling switch can be connected to the circuit of piston squirters?
TIA |
I have never herd a expert say that.......mabe a wanabe expert??Anyway they are preasure acitvated so there is no way to turn them on and off.You want to break your eng.in on the loaded side so I see no other way to do it ,,the squirters are needed for cooling not oiling.
I also disagree with the opinion.
I would mentally "uncheck" the Expert box beside anyone who said that.
-Chris |
| All times are GMT -8. The time now is 04:21 PM. |
