Curil T
Can/should Curil T be used between cylinders and case?(with copper gasket)... turbo engine
HI i do not use any sealant on the base gaskets, just clean and dry with brake cleaner
regards mike |
I think Henry Schmitt uses Curil T on the base gaskets. I haven't tried it in that application but it did clear up my acne and left my skin baby soft. :D
-Chris |
After a previous thread on this I decided to use K&W Copper Coat from NAPA.
| All times are GMT -8. The time now is 01:39 AM. |
