-   -   2.4E jetting recommendations, and other general jetting questions (http://forums.pelicanparts.com/911-engine-rebuilding-forum/207847-2-4e-jetting-recommendations-other-general-jetting-questions.html)
jim72911t 02-23-2005 12:32 AM
I posted this on the main board, but got little response, so I'll try here:
I have a 1972 911T with a freshly rebuilt 2.4E spec motor, using 2.2E pistons, as per Wayne's book. In order to defer the $2500 or so it will take to rebuild the MFI properly, I picked up a set of Zenith carbs cheap, and have since rebuilt and installed them. Good news: the car runs okay now, which it not do with the worn out MFI. Bad news: it doesn't run great, probably because I made no jetting changes before I put them on the car.
Anyway, I'm running the following jetting:
Venturies: 30mm (I bored them out when I had the carbs apart)
Main Jets: 115
Idle Jets: 47.5
Air Correction: 195
Emulsion tubes: 30 (?)
Anybody have a baseline for my particular engine? I've done some pretty extensive searches on this board and others, and I found lots of info on Webers, but little on the Zeniths. I'm assuming my carbs are still set up for a 2.2T.
More to the point: Will Weber specs work as a baseline? Being a machinist for a dozen or so years, I'm not afraid of putting my jets on the lathe and reaming them to work with my particular motor. From what my research has uncovered, a 55 idle jet is .55mm, a 150 main is 1.50mm, and so forth. Am I close? Am I crazy? If I go a bit too far, I'm sure I can find used 2.2T Zenith jets and start from scratch.
Thanks,
Jim
gumba 02-23-2005 08:19 AM
Don't know how close the Webers are to the Zeniths but here is what I'm using on my 2.4E w/40mm webers & sport muffler. I checked this set up with the LM1. Motor runs very well with no flat spots, but could use a little more fine tuning.
mains 125
air cor. 180
emul f26
idle 55
venturies 30.
kucharskimb 02-23-2005 11:01 AM
for reference...
had my webers set up on the dyno with the same motor as you (2.4E with 9.6:1). in addition, i run a crane xr3000 ignition. i'm using 60 idle and 130 main with 34mm venturies. the emulsion tubes and airs are stock. so i only had to bump up the idle and mains one size...
prior to this, then engine was a stock 2.2E. the carbs were set up on the same dyno at 60 idle and 125 main, with 30mm venturies. all else the same.
hopefully this helps some.
