-   -   Torch on a Mag case safe?? (http://forums.pelicanparts.com/911-engine-rebuilding-forum/207985-torch-mag-case-safe.html)
RetroSC 02-23-2005 04:44 PM
In the post below regarding removal of headstuds, heat seems to be the key. I have some studs that need removal in my mag case, but am reluctant to use my propane torch for fear of a magnesium flameshow in my garage. Is it really safe to put a torch to these things, or were those below referring to aluminum cases??
john walker's workshop 02-23-2005 06:17 PM
hell yeah! propane is pretty much worthless though. not hot enough. oxy/acetylene with a large, medium force flame and keep it moving. never lit one off yet.
YTNUKLR 02-23-2005 07:29 PM
Bill, I have your studs! I didn't forget about you. Please email me @ YTNUKLR@aol.com with your address. BUT, I only have 23 so you will need to heat up the case to pull one. The case is so large that it acts like a heatsink; all of it has to be at the temp of the propane torch to ignite... Mag ignites around 700* Fahrenheit, much hotter than an oxy/ace torch could get it...
RetroSC 02-23-2005 08:13 PM
ok, good info. I'll shoot you my address Scott, didn't want to keep bugging you all the time. I should be capable of removing one without screwing it up, so that should work good.
YTNUKLR 02-23-2005 08:20 PM
Bug me all ya like, I'd never do anything if it were up to me...;)
Doug Steinel 02-24-2005 04:34 AM
YTNUKLR,
You sound like my teenage son!
jluetjen 02-24-2005 04:44 AM
I used a standard Sears torch with MAP gas. It took a couple of minutes -- but no issues.
afterburn 549 02-25-2005 11:34 AM
propane and oxy are ,is a nice set up and dose most all things
