Ross Pistons
Looking to do a 3.4 turbo coversion on my 3.2
Are they better Than JE's
Williamknightperformance.com
Perfectpower.com
Old 02-28-2005, 10:39 AM
ChrisBennet's Avatar
No. MM is the only place I know that sells them for Porsches. Do a search on Motor Meister. If they were any good, you would think reputable places would also sell them.
-Chris
'80 911 Nogaro blue Phoenix!
'07 BMW 328i Coupe
Old 02-28-2005, 10:54 AM
The reason is i can get them direct from them.
My tuner which is a dsm tuner swears by them and the hates je pistons.
They have cars running 40-50 pounds of boost and spray on ross pistons
Could it be that they are great pistons but MM is ruining ross piston name?
Perfectpower.com
Old 02-28-2005, 11:02 AM
While MM certainly doesn't help anything they are associated with, that still wouldn't/couldn't have stopped every other Porsche tuner I know of from using them. Does your DSM tuner have any experience running Ross pistons in air cooled motors, maybe bikes, airplanes, etc?
Of course what I just said is all circumstantial evidence and you are right to investigate and determine for yourself. Maybe Porsche tuners follow the pack like sheep. Maybe they are unwilling to risk a motor on an unknown piston? Maybe they tried them 20 years ago and found them unsuitable but Ross has changed their "formula" since then?
-Chris
'07 BMW 328i Coupe
Old 02-28-2005, 11:21 AM
dtw dtw is offline
GAFB
Dave Brown of Speedwerks uses both JE and Ross in his custom 911 engines. He prefers the Ross pistons, but only because of the better lead time on made-to-spec piston orders.
'72 911T MFI VW Silver Metallic
'84 911 M491 non-sunroof Slate Blue
'01 996tt Lapis Blue
Old 02-28-2005, 11:42 AM
Send a message via AIM to Oldporsche
Cool
A lot of Nascar builders use Ross pistons and with good results.
I believe that MM being an exclusive distributor is a lot of BS.
Im sure if you look around, there are nationally recoginzed builders and suppliers that can get them from Ross. You might try Ross's website. I have seen the catalog on the pistons for Porsche there.
David Duffield
Old 02-28-2005, 03:18 PM
Jeff Alton's Avatar
Their website lists them for the "V6"................. those crazt webmasters!
Jeff
jeff@turn3autosport.com
997 S 4.0, Cayman S 3.8, Boxster 2.7, Boxster S race car, 996, 955 Cayenne TT, 958 Cayenne TT
Old 02-28-2005, 09:18 PM
Phoenix's Avatar
I have a used set of Ross'es from a past MM rebuild. Only 750 miles on them. Any takers?
...Oliver
'73 911T: 2.4/ PMOs/ Electromotive Ignition
'03 Audi A4 Quattro Wagon
Old 03-01-2005, 12:51 PM
JE is a great piston...I have used them in more motors than I can count. Ross pistons are just as good. You have to remember that most piston blanks come from the same place. I can tell you that running 40-50 pounds has more to do with the tuner than the piston I dont care what kind of piston you have if you go lean the motor will start using the parts for fuel I have ran blowers, nitrous, and turbos with JE's never had an issue. Call JE direct and tell them what you want...they will have the best price unless you know a friend who can give you jobber etc
Eric Hood
Old 03-01-2005, 10:55 PM
