2.4 crank into a 2.2T
I'm looking to increase my displacement and compression by swapping a 2.4/2.7 crank into my 2.2T.
Does anyone have experience with valve clearance using a 2.4 crank, T pistons, and T cam? I think the T pistons with their small cutouts might be a problem, but the mild cam should make up for it... I'm getting it together this weekend to measure everything out so I'll know for sure then. Jeff |
You need the 2.4/2.7 Rods too, then everything will be fine.
| All times are GMT -8. The time now is 01:57 PM. |
