JOT MON ABBR OTH
Groesbeck Hurricane's Avatar
Question Is this chain tensioner failure???
OK, I think my pressure fed tensioner for the 4,5,6 bank failed. When I took the covers off the 1,2,3 chain was taut and the tensioner was extended. The 4,5,6 bank chain was tight on the bottom and loose on the top and the tensioner was already depressed adequately for me to place the pin in it with room to spare.
Thoughts??? I still have the old spring tensioners.
'83 SC Targa (sold ) MANLY babyblue honda '00 F250 7.3L (MINE!)
'15 F250 Gas (Her Baby) '95 993 (sold )
I don't take scalps. I'm civilized like white man now, I shoot man in back.
Old 03-10-2005, 06:04 AM
3.2 CAB's Avatar
It sounds like it has gone south. If you could put the pin in it without having to compress the piston, it is totally crapped out, I have not seen one that bad, even the bad ones that won't stay pumped up, still have the internal spring holding tension that still had to be compressed to get the pin back in the hole. I just went through this repair myself, my right side on failed, but still had to be compressed with a c-clamp to put the pin back in it. Good luck.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 03-10-2005, 06:39 AM
