-   -   scored cylinder (http://forums.pelicanparts.com/911-engine-rebuilding-forum/209913-scored-cylinder.html)
ken martin 03-07-2005 06:41 PM
scored cylinder
I need a new cylinder,.. can't find one.. can I have the cylinder cleaned up and Nikasil coated back to spec? Or do I need to have all 6 bored and replated and go with new oversize pistons? Can someone recommend a place that can rework and re-plate?... maybe Dallas/Ft. Worth area?
thanks
Km
ChrisBennet 03-07-2005 08:37 PM
And the motor would be....
-Chris
strokher racing 03-07-2005 08:47 PM
You can get the cylinder re plated if it is not real bad. Give Stephen Kaspar an email...he did my cylinders not to long ago. You can be sure it will be done right! His email is porschephd@imagineauto.com tell him I sent you.
Eric Hood
He is in Kansas City
ken martin 03-08-2005 08:24 AM
Thanks Eric, I sent him some pictures
KM
ken martin 03-08-2005 08:45 AM
Chris, its a '78 3.3 turbo.
ChrisBennet 03-08-2005 08:56 AM
On an SC, the sealing ring groove at the top of the cylinder makes them unsuitable for boring out. I wonder if 3.3 cylinders have the same limitation.
-Chris
ken martin 03-08-2005 11:03 AM
Hummm.. don't know! Are you talking about the groove for the copper gasket that mounts to the case?
ChrisBennet 03-08-2005 11:39 AM
I mean the groove in the top of the cylinder that holds a sealing ring. The sealing ring was Porsche's way of better sealing the cylinder to head.
-Chris
ken martin 03-08-2005 09:12 PM
no grove in these
ken martin 03-09-2005 08:25 AM
Bad news from Imagine.. looks like I need to replace? Does anyone know where I can get a 97mm height group 5?
KM
