2L "T "engine, 2L "L" pistons..
Please can anyone tell me from experince if they will fit..?
I know the CR is a bit higher, but I'm asking about the valve clearance.. T cam lift and overlap is lower, but T has slightly bigger valves.. Do any of our resident Gurus know for sure please? Kind regards David |
Only way to be sure is to check with clay or (?). I’m sure the process is covered elsewhere on this site.
| All times are GMT -8. The time now is 11:33 AM. |
