-   -   Difference between 86 & 89 Carrera engine (http://forums.pelicanparts.com/911-engine-rebuilding-forum/211626-difference-between-86-89-carrera-engine.html)
Will Schulz 03-18-2005 03:27 AM
I’m in the process of replacing a 1989 Carrera engine with an engine from a 1986 Carrera.
Other than the clutch and flywheel, what other parts do I need to swap over?
ChrisBennet 03-18-2005 06:03 AM
They are plug and play as far as I know. The only "difference" I'm aware of is that the base idle adjustment for the '86 will be 800rpm vs. 880 for the '89. The upshot is that when you install the '86 in your '89 it may idle funny until you adjust the idle.
-Chris
Will Schulz 03-18-2005 12:41 PM
Where did the extra ten horses come from for the 87 and up model Carreras, the brain?
ChrisBennet 03-18-2005 01:13 PM
If you look at the ignition maps it's apparent some of it did. I'm not sure how much was DME and how much was on paper.
Remember, Porsche's stated HP figures are minimums. If Porsche found only a few motors didn't make the minimum they could have just revised/restated their numbers.
For example: If Porsche found that all the motors were making say 5 hp more than minimum they could have restated their horsepower figures without any changes to the motor. Add another 5 hp from changing the DME and you've got 10 more hp 207->217.
-Chris
Shuie 03-18-2005 03:26 PM
Some of the studs for the transmission will probably be different (G50 vs 915)
