-   -   Motor Meister (http://forums.pelicanparts.com/911-engine-rebuilding-forum/211771-motor-meister.html)
ken martin 03-18-2005 09:32 PM
Motor Meister
Can anyone coment about Motor Meister?
thanks
km
rotorhead 03-19-2005 01:02 AM
A search on them would be most informative.. I have seen a number of threads starring MM.
beepbeep 03-19-2005 02:59 AM
Run away screaming.
asphaltgambler 03-19-2005 07:33 AM
......RUN; FOREST.........RUN!!!!!!!!!!!!
Henry Schmidt 03-19-2005 07:39 AM
Research this forum and good luck.
Shuie 03-19-2005 08:12 AM
run like hell
ken martin 03-19-2005 08:22 AM
...Thanks Guys, answered my ?...
KM
vance 04-14-2005 10:16 AM
Motor Meister
Ken:
In reply to your question regarding Motor Meister. I wish I had read a message like this before I decided to send my engine to Motor Meister. My experience has been a disaster. If you, or anyone else reading this, has any questions please call me.
Vance Smith
360-665-4761
Venetian 04-14-2005 02:25 PM
Living in Canada, I have never had anything to do with them. Just curious as to how they could still be in business after all the bad press they get!! Wouldn"t word of mouth, forums such as this, lawsuits etc have done them in by now?
AL MEREDITH 04-14-2005 05:44 PM
I had them rebuild a set of three barrel webersfor me last year. I was satisfied with results...they did what they said and quickly..Al
vance 04-15-2005 05:56 AM
Al:
Maybe they are better at webers than engines. Maybe they should change there name to Weber Meister.
I have spent almost $8,000 and a year in time. And I have an engine that will barely start and run when cold. I'm just interested in getting the word out and saving pca members the agony and expense.
Any questions, please call:
Vance Smith
360.665.4761
Groesbeck Hurricane 04-15-2005 07:01 AM
Vance,
Can you go down the road to John Walker's Workshop and see what help he can provide? He's a good guy:
john walker's workshop
7613 greenwood ave. n.
seattle, wa, 98103
206.789.6800
jwworkshop@aol.com
vance 04-15-2005 07:13 AM
David:
Thanks for the info. I have an estimate from a good Porsche mechanic to repair the damage Motor Meister did to the fuel system. The problem I've spent all the money I can afford, and the estimate is approx $2,500. Essentially to replace the fuel system that was working fine when the engine was removed and shipped to Motor Meister.
MikeSid 04-15-2005 09:14 AM
I think a MM sticky might keep this from coming up every week. Then again, not sure I wanna see that on page one every day.
asphaltgambler 04-16-2005 08:51 AM
Venetian........... To answer your question, because it is a good one, MM has the slickest, most consumer-friendly Porsche repair shop website out there. Very alluring.
BALTO 04-16-2005 09:45 AM
I boght :carbkit(zenith). P/C. regrind my cams, rebuildkit for my SC from them. No problems and a lot of tech suport from Lee .during my rebuild
BTW:the pistons/cyl is there "home made" 101mm type
I must be a stupid dear devil
Phoenix 04-16-2005 01:42 PM
Please do a search here and read through my story and the stories of others. I'd hate to see anyone else go through the same horroe.
This board is the best Porsche resource you will ever find. The collective experience of members is incredible. I'm sure someone here can recommend a good trustwortyhy mechanic and shop in your area.
MM makes a great first impression and "says" all the right things. The old adage is true here. If it sounds too good to be true, it usually is.
I only wished I'd listened to that piece of advice and had this board as a resource before I got caught up in MM hell, the effects of I'm still dealing with.
vance 04-16-2005 06:08 PM
Phoenix:
We may not be able to recoup our loses with Motor Meister, but if there are enough of us we may be able to petition the editor of Panorama to drop Motor Meister's advertising. Panorama, expressly, does not assume any liability for claims made by their advertisers, but if enough of us complain we might get their attention.
Phoenix 04-17-2005 05:07 PM
Vance
I work in advertising specifically media planning & buying. Unfortunately, for Pano to drop a long term advertiser such as MM, it would take several hundred signatures from Pano subscribers or several documented cases where MM was clearly found at fault.
The better approach would be to combine the efforts of 4+ people who MM wronged each having full documentation. We could then collectively bring forward a class action suit with the proper authorities. In the end MM might be willing to cut a deal but I doubt it would be enough to recoup our losses.
My engine still isn't right and I'm hoping to save enough to have PP's Henry Schmidt or a well regarded and respected local P-only mechanic build a completelt new motor. Only then will I have purged all the MM demons out of Phoenix. (Of course this will cost me only a bit more than the same nearly 10grand I originally shelled out to MM. VERY tough lesson learned.)
Ken - sorry to hijack your thread though this certainly is relevant to your original question.
justin 04-20-2005 08:51 PM
RUN HUMP RUN...
