e-cams
Hi guys, I'm building a 2.7 with e-cams and webers.Here's the problem: cams have the extention on the back end for mfi gear and are too long for my housings,Can I cut the extentions off flush with back side of that bearing so they fit?Thanks,T.C.
Old 03-22-2005, 05:55 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Just punch out the back of the cam carrier, then install the MFI cam drive seal. No wierd modification needed, and the seal is only a few dollars.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Old 03-22-2005, 06:06 AM
e-cams
Thanks Tim,T.C.
Old 03-22-2005, 06:37 AM
Warren Hall Student
Bobboloo's Avatar
You'll also need to either swap out your back plate tin for that side of the motor with the MFI version or cut a hole for the extension to go through.
Better yet. Put a pulley on that cam and install MFI induction.
Bobby
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 03-23-2005, 12:52 AM
