RSR rocker seals.....
I recieved these from our host today......they are flat rubber washers sort of..can some one steer me as how they are installed??????just put them on the ends???
I thought maybe they would be "O" rings that go over the shafts some how.......but anyway need direction here Thanks! |
Just slide them over the end carefully, they can tear. Once they are on and in the groves the design will look normal. When I got mine the first time, I thought they looked a little strange too.
Jeff |
Just put the on the ends and slide them on until the fall into the groove. I don't know if it makes a difference but I try to make sure they don't "roll over" and get inside out when I install them.
-Chris |
Ok!! thanks dudes......the grooves.....its been awhile seince apart....all coming back to me now..Thanks!!
| All times are GMT -8. The time now is 06:37 AM. |
