-   -   Replaced My Chain Tensioners (http://forums.pelicanparts.com/911-engine-rebuilding-forum/212789-replaced-my-chain-tensioners.html)
PJMARKOW 03-24-2005 10:30 PM
Well I finally found the time to replace the chain tensioners on my 1977 930. I removed the headers, and then the turbo & muffler as one unit. I couldn't see anything wrong with the old tensioners but I had new ones so I replaced them any way. When I finished and fired the engine up the chain rattle noise was still there. I didn't know what was going on, until I pushed the clutch in and the noise disappeared. It was the bloody clutch throw out bearing. This is a brand new bearing. I replaced the old one when I installed my modified pressure plate. The 930 throw out bearing just sits inside the clutch spring and is supported by the release fork. The bloody thing is rattling really loudly and it's driving me crazy. I adjusted the clutch a couple of times but nothing helps. Anyone else have a problem with 930 clutch throw out bearings? On a more positive note, I have my EFI just about tuned and the results are fantastic. I've done all of it on the road and when I get a chance, after I've finished the break in, I'll get it on a dyno and do the timing. The K27 HF starts boosting at around 2300. I've only reved it to 3500, but can't wait till it's fully broken in. I can get into 4 gear a lot earlier with my new setup.
Cheers
David 03-25-2005 07:18 AM
What do you attribute the earlier boost to? I would figure the HF would spool up later than a regular K27, is the better fuel control and ignition the main reason?
PJMARKOW 03-25-2005 02:28 PM
I think it must be the design of the K27 HF. I've logged all the engine parameters so I can tune the engine on the road, and that's when I noticed how early the boost started. It's certainly noticeable when I'am driving, but I haven't been able to try the top end as yet.
Brother 03-25-2005 03:32 PM
What kind of EFI controller are you running?
PJMARKOW 03-25-2005 06:46 PM
I'am running an Australian made EMS Stinger ECU.
